I have had this TTA for 8 or 9 years and i have never had a problem (trans replacement 8 years ago). I replaced spark plugs (AC), O2 (AC), Vacuum Block (Kirbans), valve cover gaskets, Fuel Filter, Belt, tensioner Pully and altenator. I replaced these items for maintanence no other reason Altenator was replaced due to bearing noise not charging reasons. Took the car out for a drive afterwords no problem went back home picked up middle kid to take to Baseball and car did not drive right, Symptons very rich idle, lazy down low in the RPMs. Have been going over things the last couple of days and it has gotten somewhat worse it is throwing code after code- esc problem-Maf out of range-no cam signal-no crank signal - lean exhaust - rich exhaust - prom error- ecm malfuntion they continueally rotate through my scanner.
MY mods are nothing internal - TA49-30lb-RJC boost control-RJC plate-LT1 MAf-translator-Extender- Walbro pump-hot wire- it is a very well maintained car not really raced (Capital 7 or 8 years ago last time).
CAR does drive
I replaced the module with a new GM module- no differance - checked all grounds -OK- changed out plugs again - no differnace. checked sensors-OK.
no water in oil and no oil in water. Vacuum guage is 18/15 but does drop off when vehicle idle becomes erradic.
any help would be appreciated, I am stumped
CAR does drive
