Shurflo pump location on GN
dvldoc
What's the best place on a GN and the easiest to mount. I found a good post on here but all the pic links were dead.
i mounted mine on the right bumper bracket/support. i only used one side of the pump bracket to mount the pump.
i have pics but it is 1am. good night.
ill put them up tomorrow.
Same here, right side bumper braket support, easy to get to. The only other place is behind the head light but is a real PITA to get to and drill holes for it.
So how much line is needed for the fluid tank to the pump and the pump to nozzle?
Razors kit came with enough already attached. I can measure later this evening, but its about 2' on the supply and about 2.5' to 3' on the nozzle side. You just have to make sure the pump head is lower than the bottom of the supply resourvior....and thats about the only 2 places you can mount it.
