My Son-In-Law is working on some engine modeling software, and needs some info on SII cam specs.
We would like to start on modeling a Buick V6. We're going to take basic measurments of runners and valve seats from the hardware that I left him(head and intake). We'd like to get your help on tracking down cam data. At the very minimum we would like to have lift, duration, and lobe separation numbers for cams the most popular SII cams that would be good into the 800+HP range. It would be better if we had actual valve lift and or cam lobe dimensions per degree. The best scenario is to populate a lift vs degree table and input it into the model. I'm hoping that someone has already measured some of the cams and is willing to share the data. we made an unsuccesful attempt to get in contact with turbobuick member Todd King who used to work at SouthWest Research Institute and has done some impressive testing on turbo v6s. He might have more detailed cam specs.
After the model is built we can analyze different scenarios, i.e. differ stroke, bore, change cams, static compression ratios etc etc. The objective is for him to better familiarize himself with the engine modeling software and for us to dream up and look at different hardware scenarios
If you are interested, could you help me by providing cam data?
P.S. He could always model it using camless actuators but then be limited to 6k RPM. haha
