For those of you with easy access to a set of SII head. Can you measure your rocker shaft height for me. The height above the valve cover flange that is. That seems to be the only flat surface available to measure from, and is probably the only part of these heads that doesn't get modified/moved.
These heads I have, have a rather unique rocker shaft mounting system, and someone speculated it may have been raised up to accomodate longer valves.
I really don't think the shaft appears to be raised but would like to verify this with some comparison measurements. I'll see if I can snap a picture and post it later.
