Ok so last week I pull my Holley stealth ram intake of my 89 iroc-z and swap a new single plane intake with a elbow and ford 90mm TB. The car worked great when I pulled it into the garage last week. I drop the distributor in and go to fire it up and the car runs for 2-3 seconds and dies like I pulled the power wire to the ecu. The ecu is a FAST batch. I have checked everything and just about fed up. I did bypas the coil and mallory ignition box and just hooked up my stock coil, no dice. The tps is at 19 so the new ford tps with the GM connector is hooked up correct. What the hell gives all I did was swap intakes all in a weeks time. I did try an old ignition module I had but nothing.
Anything to look for with my FAST?
