Size of huge cam nut on harmonic balancer?
Guess
87 GN
Does anybody know the size of the big cam nut on the harmonic balancer? Is it 28mm? Taking a guess. O'reilly's says they can't order that size. Thanks.
It's 28mm but a 1 1/8" will work, just a tad loose.
I think you have that statement backwards! :biggrin:
This is the same bolt used on Buick V-8's from back in the 60's, and the designation on the head signifies SAE grade 5. I have yet to see GM use a SAE bolt with a metric hex head?
My 1-1/8" sockets have worked on thousands of Buick crank bolts, and probably a 28mm will work too.
I know north of the border, metric is more common up there, but some of us here still have trouble wrapping our brain around this "metric thing", especially on the T-R's when both SAE and Metric fasteners were mixed?
Among my favorites are bolts that are SAE on one side, and the hex/stud threads are metric on the other side. :confused:
Maybe it's my Canadian car.:biggrin: I used the 1 1/8" as well, but I did find the 28mm was a nicer fit, not that it matters much at that size.
I assumed it was metric. In any event, the 1 1/8 was a little loose, but a cheater bar and bumping the starter loosened that baby easily!
