Slick and Wheel fit?
Vader 87
Licensed
Any problems mounting a pair of 28x10 MT ET Drags on some 15x8 weld pro stars?
TIA
Vader,
Jesse one of our moderators has this combo on his car. It fits well with no problems. Its kinda tight out back by theframe rails as it sweep out over right before the tail pipe. If your rear end is not centered you could see some rubbing.
Good Luck
I run these tires on my car. You have to make sure your welds are 3.5 backspacing these tires will not work with 4.5. I run the slicks on the 3.5s and I run radial 275/60s on my 4.5s. Hope this helps.
That is correct i should have mentioned that he runs them on a 3.5 in BS(ooppss)
Jason ,
I run the same slick ,28x10.5 on a 15x10 rim. 5 in BS but my frame is notched.
Thats fine because i currently run 26x10 MT ET Drags on 15x8 prostars with 3.5" back spacing...i just wanted to make sure these same wheels will fit ok when i upgrade to the 28x10s
