I noticed a small bit of moisture on the up pipe where the injector is inserted. I will first try to tighten it further. If that doesn't work, I plan to use some J-B Weld to seal it.
Do I simply apply the weld around the nozzle on the outside of the up pipe ? Can I do this with the up pipe on the car or should I remove it entirely ?
