Hey guys, I'm having a slow spool problem with my GN. I can hit full boost and 02 is about 780-800 but its very slow on the bottom. I sprayed carb cleaner on my vacuum lines and no bog. I changed my maf to a known good one and it brought my blm down from 150 at idle to 105-110 at idle. I thought for sure that would cure it but I'm still slow to build boost. I read that by pulling up on your EGR your car should bog. After trying that I was stumped because my car did not bog. Just so I know I did it right, is the EGR that round black thing on the driverside vacuume lines? At idle my AF is 5, Blm 105-110, tps .44, iac 40-60. Any suggestions?
