DailyDrifter
The Slow and the Curious
- Dec 5, 2007
What would cause the engine to be slow to build up RPM's? The tune is good, but the car doesnt want to rev up when under a load. It also sounds like the exhaust is comming out the intake valves (BTW new springs were installed 2 weeks ago). I can only get it to rev up to 4300 rpms and it has no power. The cam is 212-224 roller. Boost is set at 20 psi. Coil and IGN module are good, No MAF. Some more info in sig. Also injector duty cycle comes in slow and goes to 60% at 4150 RPM. It has to be something mechanical, because I connected the stock ECU in and it still did the same shannanigans Any suggestions would help out greatly
Thanks, Dave
Thanks, Dave
