SM charging numbers?
gusszgs
Guys, what do you see for volts on the SM when cruising and hot?
I'm seeing 12.9-13.4 range. SM is 2.2 so quik update. Just a little concerned when taxing the system at WOT and the FP demands increase. FP is hotwired.
Is this acceptable or should I be seeing closer to 14 volts? Its just the factory alternator and a little long in the tooth. TIA
Unless you have the Scanmaster ground running directly to the battery, you cannot have a valid number for measuring voltage.
Attaching the SM ground wire on the dash is not a proper place as the ground circuit there has a lot of resistance.
You also need to check voltage at the fuse block to assure proper voltage is present there as well.
I have seen voltage as low as 11.9v inside the car when the alt is showing 13.3v!
Nick how does one go about correcting that problem?
I "assume" you are asking about the interior low voltage issue?
In my 30 year old Limited, I was concerned about the XFI showing 11.9 - 12.3 voltage even at WOT.
Thanks to a good friend who has 40 years experience as a GM tech suggested to replace the ignition switch at the lower end of the column.
That $20 part gave me within .2-3 volts of the alt voltage at the fuse block!
I also ran a heavy gauge wire from the battery ground to the metal frame of the dash which may have also been a help too?
After messing with these cars for 30 years, I am very fortunate to have many "experts" that help me beyond my knowledge and experience to solve issues, as well as bring these cars into the 21st. Century! :)
Thanks for the input Nick
So if I take a reading off the alternator and the volts are higher can I ignore the SM reading knowing that the hotwire kit is in place?
