John Larkin
Sublime Master of Turbology
- May 25, 2001
Briggs & Stratton 11hp rear engine Snapper rider. L-head. Used to start first or second pull and has run great since 1989. Two weeks ago it started cutting out under load. Now I can sometimes get it to start and idle but as soon as I put it in gear and go, it sputters to a stop. New plug, correct gap, has spark, fresh fuel, new fuel filter, new fuel line, took carb apart, cleaned and reset float and screw adjustments, set governor, set choke, removed gas cap to eliminate vapor lock. It gets plenty of gas at idle, I can see it spitting in the inlet. Runs the same with or without the air cleaner.
I am stumped and the leaves are starting to get the best of me. It has to go to the shop unless someone has a miracle I have not thought of yet. And I hate paying the shop.
