Small engine parts and bolts needed
wickedtt
I'm building a spare motor and need some small parts and bolts
1. If you have all the front timing case cover bolts..
2. .I need the block off plate on the side of the timing cover with the bolts.
3. intake manifold bolts
4. Balancer bolt
5. oil sling that goes on the crank and behind the timing cover.
6. Brass fitting for the front of the block that the oil return line screws into.
7. The small brass block that the oil sender and oil feed line go to.
8. cam sensor hold down bracket and bolt
Whatever you have with a price including shipping to NY;)
