small problem with electronic plug near shift linkage
jessecool
I recently installed a 85 Turbo drivetrain into a regal limited. I am using the 200R originally from the 307 V8. Everything matched up, except the small square plug on the driver side next to the shift linkage. Both plugs have four wires, but the notches in them do not match up. Is there a way to connect this?
Well...fixed the problem. The plug was for the lock up on the Torque Converter...got it wired in and a toggle switch to manually lock up as well.Thanks fred...hurry up and get your car to the track so i can see you pull low 9's with that new stage block
