SMC pressure test...
DynamicGN
I am getting 60-65 psi with pump speed max by hitting the test button...i was getting 40psi but steve installed a brand new pump, great service by the way...is there more pressure when the test button is not used and the system sprays when the turbo hits its desired point?
Pressure will vary some with battery voltage, and the setting of your pump speed.
And realize 60 PSI nozzle, and 25 PSI boost=35 effective.
If you hit your test button and get 60 PSI.. that is how much you'll get once the system activates.
Good Luck. And you can always contact Steve at SMC for clarification.
