there is no reason it should go bad sitting , if it wasn't used and was stored properly it should work as good today as it would have back then , only way to know if it works is test it ,
you could ship it to razor and he could test it and if it is bad and you plan to get a new pump he can let you know what you need to do to run a newer pump depending on how old the kit is
there were some changes made through years and depending on how early the kit is you should talk to razor about using a newer pump as well as running an older pump
call him
