Got a question concerning my SMC alky kit. Recently I have noticed that sometimes the alky is not coming on (starting to spray) at where I have it set at. The pump is turning on however sometimes it seems like it takes a while to begin spraying.
Tonight I used the test button the check the alky kit (parked w/ ignition on) and after it began spraying the alky gauge quickly showed 100psi. But as soon as you let go of the test button, alomst instantly all pressure is lost in the alky lines. Should'nt it hold some pressure? I'm thinking I have a bad
in-line check valve which is allowing line pressure to be lost instantly after the pump stops. Or, is there such a valve in the pump itself?
Anyone got any ideas or familiar w/ this SMC kit?
