SMC square bottle non-pro, meth or alky?
turbowannabe
What fluid can I run in this thing? It's a square bottle, duel nozzle, non-progressive kit that came on the car I bought. Let me know
Denatured alcohol with an ounce of Uplon Klotz as a pump lubricant in the alky tank would probably be best. For that system, that's what Steve at SMC recommends. ;) I like to mix mine up ahead of time in one gallon containers and shake well before pouring in. Do not let the pump get dry and keep it submerged at all times!
Thanks! I was really hoping that I coule run methanol since it's cheaper, but oh well. Is the Klotz lube like a 2-stroke gas mix lube that you would get at a motorcycle shop?
-Dan
Klotz Synthetic Lubricants - Products
If you have a carting place nearby, you can fund it there. Summit also carries it as well as SMC. That link I gave you should give you distributors if you snoop around some. It's a lube for that particular type pump. Do not use 2 stroke oil for premix or injectolube on the 2 stroke motorcycles in the SMC system as it's not the same! That I know since I have an old 2 stroke 3 cylinder motorcycle I rebuilt and restored.
