Smoke issue
Blue smoke ? Usually one of three things. Leaking valve guides - will blow on start up, leaking rings, or leaking turbo- remove the downpipe and look for oil build up.
If its black smoke, you're running rich - a bit common with these cars unless it is excessive, and if its white, your burning coolant !
