Smoke problems
bkosonen85
I have a 85 GN. I put a new turbo on due to the factory one blowing and leaking oil. However I'm still getting a ton of smoke when running. It was blowing the dip stick out so I put a new pcv valve in and kinda helped.
Any ideas ? Engine is pretty much all stock.
Sent from my SM-N900V using Tapatalk
Double check your vacuum lines and make sure your turbo is getting oil, if all is we'll let it run a bit to see if the smoke clears. I Have a question for you have you adjusted the cam sensor lately???
I suspect you have a pressurized block. This means the oil cannot drain out of the turbo into the lifter valley. Oil then leaks out of the turbo and into the exhaust system. Smoke is probably white. Try and remove the oil filler tube cap and see what happens. I went through 3 turbos with this problem.
