smokeing under accel
pracingrev1140
hi all my gn has 128000 miles on it ,im starting to see light blue smoke ,when i mash the loud pedal under boost.just wondering could it be valve seals, or turbo seal any comment s are welcomed thanks RR
Yes. It could be either or both. Time to run some tests. Do a compression and leak-down. Are the plugs oil covered? Pull the IC and see if you have oil there or on the exhaust housing. 128k is about time for an overhaul.
over haul are you talking engine or just heads? the thing still pulls hard doesnt ,seem to have lost any power just the smoke its aknowing.
Think he was saying to re-do the motor. Even if as you say it's only light blue smoke. Still is oil. Save your self the time and agervation. And freshen up the block. I have a 153,000 Limited.
Though only a turbo seal is wrong. It's time. Trying to save you.
HTH'ED......................
