626gn
- Feb 15, 2009
My car sometimes blows blue smoke out the tailpipes after idling for a few minutes after startup and I’m finding oil in the tailpipe. It doesn’t smoke a whole lot but enough to know something is not right. It also seems to come and go and doesn’t blow smoke constantly. I’ve pulled the up pipe, checked the IC, and exhaust side of the turbo expecting to find oil but both sides are as dry as can be. I also replaced the PCV (BLM’s improved
but the car continues to smoke).
I purchased the TA49 fresh off a reconditioning and it has been on the car for only 3 months and 400 miles and has already developed some thrust play. ~.0313 if I had to guess. Minimal side to side play, not enough to contact the housing as far as I can tell.
My question is: should I still be looking at the turbo as the culprit even though there is no oil on either the hot or cold side? I read a post by bison saying it only takes a small amount of oil to produce smoke. Could my turbo seals have developed a small intermittent leak causing it to smoke but the oil burns off before producing any visible evidence on either the hot or cold side of the turbo?
