Smooth collar for column/floor shift conversion
INEEDAGN
Seen Your Member
Credit goes to Eric Fisher (turbofish38) for this tidbit. Apparently you can convert your column shift steering column to floor shift specs by swapping in the smooth collar from a 3rd or 4th gen camaro/firebird or a 1st or 2nd gen. J body (cavalier/skyhawk/sunbird) with automatic on the floor. You will have to disassemble the column and swap only the collar.
Obviously, you could use the collar/column from another g body as well.
http://turbobuick.com/forums/threads/split-bench-to-bucket-seats.374440/#post-3008603
