Snow Plow guru's ???
Little6pack
Guy's I have the chance to pickup
a 1972 Blazer 4 wheel drive truck CHEAP!.
It has been in Mass & New Hampshire for about 5 years
via California its prior life.
Since living here in the rust coast it must of seen
some salt because the wheel well area paint
is bubbling with rust.
MY ????'s
The truck is to far gone too restore but would it make
a good plow unit for driveways?
Do they even make plows for these anymore?
How does a plow operate? Hydraulic pump? Electronics??
What is the cost of a new plow setup these days
Hahaha, your gona get Big Blue? Chris is going to kill you if you put that in the yard too! Is the POS still stuck in 4wd?
Yeah, she has yelled many times which I am use to buy now.
nagg nagg nag...
Yes the truck is stuck in 4wd :(
Just want to plow all the old farts on my street or surrounding area.
At $20 bucks a whack for 5 mins of work that is pretty darn good.
The bigger the driveway the more $$..
I can always sell the plow unit or truck/plow in spring.
A used blade would run you around 1000 minimum but going into plowing season maybe more. They run on hydraulics and unless you can get that truck out of 4 wheel drive I wouldn't buy it.
