boostingbuick
Going to be buried in this.
- Aug 25, 2002
Ok, I am helping one of the board members with his 87 GN. He removed a t45e turbo and installed a 70 hpq turbo. Nothing else was changed. Now when he stands on it the car surges or bucks and will on occasion, backfire. The old turbo was a 3 inch in and 2 inch out. The new turbo is a 4 inch in and 3 inch out. However, the inlet pipe is a 3 inch with a 3 to 4 hose and the outlet has a 3 to 2 1/2 for the 2 1/2 inter cooler piping. I find it hard to believe the pipes could cause this but nothing else has changed. If you slowly tip into it to wot it seems to be fine. But sometimes will buck. However, if you mat it, it will buck all the time. Boost was 20 psi on 110 race fuel.
----Now the things I did.-----
Replaced plugs - r42ts plugs gaped at .30
ohmed wires. Magna core wires - 4.0 ohms. Switch wires with my car and no change.
Swapped coil pack and module with my car.
Inspected fuel pressure under load to insure it was not falling off.
Inspected A/F with a wide band. 11.8 at WOT when it does run good.
Inspected TPS at idle (.44) and slowly went to WOT and had no issues.
Swapped out Mass air with known good one. (stock M/A)
Inspected all air hoses and inter cooler. V2 front mount.
No codes present.
All other sensors working good. Coolant-air temp-tps and etc.
Inspected to insure cam sensor was not 180 off. Was not.
Ran with dump open and closed, no difference.
Added ground from Ignition module to firewall. ( redundant )
Any idea's?
No codes present.
Any idea's?
