Guys,
I'll start with a little history first. The car has sat for 4 years before I picked it up in October. So this winter I wanted to do the rear brakes because I was advised of a cylinder leak. So I did, which was kind of a PITA as this is my very first drum brake job. I put new S10 wheel cylinders (I got the part number off of here) new shoes and turned the drums.
I did buy a new hardware kit but one spring does touch the wheel cylinder rubber boot is that ok? Anyway, the brakes work good (I had the local mechanic check them, help adjust them and he said they look fine even with the spring touching the little rubber end a little on the wheel cylinder). I can lock up the rears REALLY easy. So I adjusted them (with help from the local mechanic), sanded a little on the drivers side and seems to be pretty good now.
So I took the car for a ride and it has a REALLY soft pedal. 4 or 5 pumps and the brake light would come on. Then the pedal got stiff.
So I knew the former owner (my brother) said the master cylinder was bad and sold a brand new power master with the car. I figured that was it so we replaced the power master bleed the brakes and did it again.
Same thing pump the breaks 4, 5, 6 times and the brake light would come on. Break pedal was super soft. Once at the end of the travel it would lock up the breaks though. That's where we stopped. Anyone have any idea?
The motor on the new powermaster runs when I turn the car on. Just the pedal is super soft all the time. It does get a little harder after hitting the breaks a few times but still really soft. The break light comes on in the car after a few times of pumping the breaks
Help turbo guru's help!!!!
TIA,
Watz
TIA,
Watz
