I replaced the power master and now the brake pedal is too soft. There are no leaks and I bled them both at the master cylinder and at the 4 corners. I attended a seminar once at Bowling Green, where Richard Clark said if you tighten a screw somewhere on the powermaster, your brakes will throw you through the windshield. I don't remember where he said that screw is located, and I couldn't find any screws on the P/M. Mechanic said to maybe adjust the rear shoes, but they worked better before I replaced the P/M. Any suggestions? Could the new master cylinder be at fault? Also, it came with the new style accumulator. Could the old style work better? Thanks.
