fastblackracing
- Apr 7, 2009
I have a set of injectors that came out of a Turbo crate motor that came from GM thru a GM employee.
The injectors only have whatever run time on them that GM put on the motor before crating it up, likely only a few minutes judging how clean everything was when I took the motor apart to put steel caps, ported heads etc....
You can tell by the crisp yellow coloring on the nozzle ends that there little run time on these.
Priced at $100 dollars shipped to the lower 48. Will ship elsewhere for a few more dollars.
I will stand behind these to work as they should, for 30 days.
Thanks,Mannie.
Thanks,Mannie.
