fastblackracing
- Apr 7, 2009
I have a set of injectors that came out of a Turbo crate motor that came from GM thru a GM employee.
The injectors only have whatever run time on them that GM put on the motor before crating it up, likely only a few minutes judging how clean everything was when I took the motor apart to put steel caps, ported heads etc....
You can tell by the crisp yellow coloring on the nozzle ends that there little run time on these.
![image.jpg image.jpg](https://turbobuick-data.community.forum/attachments/256/256898-d3b3b038daa2a6bff28c7ff6954b6d56.jpg?hash=07OwONqipr)
Priced at $100 dollars shipped to the lower 48. Will ship elsewhere for a few more dollars.
I will stand behind these to work as they should, for 30 days.
Thanks,Mannie.
Thanks,Mannie.
