Solid cam specs?
drturbo69
Anyone know the specs. On this roller cam? Pre-turbo & engine bv6-251-r10 p1005 think its a solid
thanks doc
Guess i will call precision turbo monday-anybody special to talk to there.
Looks like for production type heads-billet thanks doc
I didn't catch the "Pre-turbo and engine" as Precision... I just thought it was a cam for a NA "pre-turbo" motor... :) I will have to search some more, see if I have any old Precision catalogs... I know searching the internet using that number comes up with nothing.
Called dan at dls 251 duration has no other information-he said may have been in alan witters? Engine.it is for stock type heads not stage 2.
Doc
On their old cams the R10 was 110 lobe seperation. Alan Whitter had a 248/248 so did I at that time. Where did you get it from?
Mike
Hey mike came with a bunch of parts had for about 12 years-may use in 3.625 stroked offcenter stage 2 with max ported m&a heads.not trying to set the world on fire-but dont want to use if not good? What power range is it good for?
Thanks doc
if that is what i think it is you will need to shift that up around 7500 - 7800
