Hey guys..got a few questions...
1.if using main studs...what needs to be done to the block..if any...what could be the effects of just putting them in to a stock block during a rebuild??
2.shouldnt there be a loss of oil pressure when theres a rod knock??even if its light???
3.will to much side clearance between two rods sound like a rod knock..maybe slap each other??/
4.when resizing rods and the such...wouldnt a rod thats out of round show up...and can arp rod bolts be reused or replaced???
5.if theres a blockage or restriction/obstruction through the oil passages wouldnt there be erratic oil pressure readings???
Thanx guys will have more later im sure....vinny
