some left overs for sale.
Gbodyolds
Bosch adjustable fuel pressure regulator used but in good working order was 119.00 new 60.00 shipped
ATR Pit bull chip New never used special ordered for 72lb injectors a standard pit bull chip sells for 119.95 dont remember what this cost me 75.00 shipped
Stock 87 GN chip excellent condition worked perfect when removed 25.00 shipped.
used stock fan with motor low miles 50.00 shipped
GM fan relay for GN new in box 40.00 shipped
Stock GN 20 bolt oil pan 25.00 shipped
Pro charger FMU 40.00 shipped
Typhoon Stock Fuel Rails with Bosch adjustable fuel pressure regulator used but in decent shape, regulator alone is 119.00 new 150.00 shipped
aftermarket rear swaybar for typhoon 60.00 shipped.
B&M holeshot 3000 series 30 spline convertor for 700-r4 and 4l60E used for 300-500 miles summit part # BMM-70425 was 529.00 new 400.00 shipped
ATR intake gasket for use when installing Vortec heads on a sy-ty block stock gaskets are 100.00 these cost a lot more 75.00 shipped
for Syclone/typhoon
complete short block still assembled on an engine stand this is a low mile motor 30 something thousand was going to freashen it up and do a hybrid with it but plans changed. will include with it a new ATR cam and ATR gasket kit, it will also come with the heads timing cover, distributor, water pump and pully, balancer, oil pan, all the hardwear pushrods, lifters, rockers, valve covers, oil filter re-locater and so on basically you are buying a complete motor minus the intakes, manifolds and accessories. the cam and gaskets were almost 600.00 alone it like to see 1000.00 for everything.
Typhoon AC compressor good shape works 100.00 shipped
Typhoon AC condensor 50.00 shipped
Typhoon evaporator 30.00 shipped
Typhoon AC lines 75.00 shipped
