It was finally nice enough weather I could carry my Grand National out for a drive yesterday and do a quick photoshoot. The car is AMAZING...it will break the tires loose at 60mph! Its buy far the fasted car I have ever owned (and I have had over 30 LS1 cars!)
Mods are....
Mods are....
Engine:
Ported stock heads
New valves and Springs
RJC Headgaskets
Head Studs
PT 70 turbo with a P-Trim Wheel
Ford power Stroke intercooler
LS1 Mass Air Flow Sensor
RJC Power Plate
4" Big Mouth Cold Air Intake
Razor's Alky Injection
Keith mease 3" down pipe
3" ATR single shot exhaust with cut out
TA performance headers
Power logger data logger
lc-1 Wide Band Sensor with Gauge
Turbo Tweak Chip
65lb/hr Injectors
Transmission:
Freshly rebuilt by Jimmys (His best rebuild! )
Vigilante 9" lock up 3000 to 3400 rpm
Rear end:
Eaton Posi
Moser axles
New bearings and gears - stock 3.23 ratio
TA Performance Rear Cover
Chassis/suspension/Body:
6 point roll cage
Metco rear suspension
Bilstein Shocks
Rear Air Bags
Body braces
5 under hood braces
Rear seat braces
Corvette Z06 Front brakes w/ Line lock
SIMMONS 17in wheels
BFG tires with only 400 mile on them
PST suspension bushings in the front end
Front lowering springs
Corbeau seats
Corbeau 5 point harnesses
Fiberglass front and rear bumpers
Driveshaft loop
Ported stock heads
RJC Headgaskets
Head Studs
RJC Power Plate
Turbo Tweak Chip
65lb/hr Injectors
Transmission:
Rear end:
Eaton Posi
Moser axles
6 point roll cage
Bilstein Shocks
Rear Air Bags
Body braces
5 under hood braces
Rear seat braces
SIMMONS 17in wheels
Corbeau seats
Driveshaft loop
