Chevrolet Monza "Grand Sport" STW 1978
Engine:
• Chevy smallblock 350 V8, model year 1988.
• Corvette ported aluminum 58cc heads, roller rockers, 10,3 comp ratio
• Owner-modified original ribbed steel valve covers
• Hydraulic roller cam, STD and Comp Cams "305"
• True roller timing gear
• Corvette aluminum water pump, lightweight pulleys
• Intake manifold designed, calculated and made by owner
• Fuelrails and all related pieces designed and made by owner
• Wiring harness modifications and add-ons made by owner
• Altered water circulation system made by owner
• Electronic Control Module modifications, fully tuneable with laptop (included in sale)
• 2x58mm 1000 cfm Accel throttle body with TPI TPS
• Air cleaner box made by owner
• Hooker headers
• GM lightweight superstarter
• Remote-mount twin-oilfilter setup
• Twin 2,5” exhaust, rear twin-muffler made by owner
• Various miscellaneous parts from Mitsubishi, Opel, Alfa Romeo etc.
Transmission:
• GM TH 700 4R 4-speed automatic with overdrive and shift kit
• Computer driven lock-up converter with VSS.
Front axle:
• Chevrolet Monza V8 crossmember with double A-arms
• Thicker than stock coil springs, KONI adjustable shocks, 2 ¼” swaybar
• Modified wheelhubs with 13” (330mm) Wilwood ventilated motorcycle-type discs and Corvette 4-pot brake calipers
• Upper A-arms swapped from left to right and vice versa
• BMW M3 wheel alignment
Rear axle:
• Narrowed Ford 9” axle, Auburn Limited Slip with 3.89:1 gears (3,50:1 gears also)
• 12,5” (318mm) Corvette ventilated discs and 4-pot brake calipers
• Drum parking brake from various Peugeot, Volkswagen and homemade parts made by owner
• 3-link suspension setup with Panhard bar, 1 ¾” swaybar
Interior:
• Tan vinyl upholstery. NOTHING painted!!
• Original seats and panels, every piece covered with the same material
• Dash and instrument panel reworked by owner
• Gauges by Autometer
• Steering wheel from various parts, B&M ratchet shifter, tilt column
Exterior:
• Reinforced bodyshell, Gloss Black paint (VERY good condition, not one scratch, dent, ding or rot)
• Fiberglass bumpers
• Corvette Grand Sport –emblems
• Painting modifications to shiny parts to get modern exterior look
• Fiberglass hoodscoop modified from Dodge Swinger dual hoodscoops
Wheels and tires:
• Ronal-cast aluminum wheels, altered scheme
• Tire size 225/40 R18 front, 235/40 R18 rear
Exterior photos:
Photo inside:
Engine:
Front brakes:
PLEASE NOTE:
Car is in Finland, Europe.
I can help set up the freight.
Price is 27.000 USD.
Possible trade: 1999 or newer Dodge RAM 4x4 with Cummins TD and automatic
Contact info:
jari.vasarainen@nokia.com
or
+358-50-486-8026 (cellular)
fluent English spoken
Engine:
• Hooker headers
Transmission:
Front axle:
Rear axle:
Interior:
Exterior:
Wheels and tires:
Exterior photos:
Photo inside:
Engine:
Front brakes:
PLEASE NOTE:
Contact info:
or
