trading t/a
I'm Angry!!!!!
- Aug 6, 2001
Well on Sat I installed the power plate(damn easy compared to a TPI plenum). When I took the tb off and looked down the intake runners I noticed they were port matched to the cylinder head(can see where he scratched the inside of the intake). Upon further investigation I used a flashlight to look as far inside as possible and noticed at the end of the runner(head) it was also ground out and very shiny. So it looks like there is at least a p&p job on the heads. Now I'm starting to wonder if the cam was changed also. Am I right in thinking that the reason I was seeing lower boost when the wastegate actuator was set to stock was because there was less of a restriction in the ports? I have the urge to rip it apart this winter but it runs really good now.
One other thing while programming boost fuel am I right in setting it to a leaner af for spooling? I can run 16-18 psi on the street with no knock(even on the launch and gear changes), but the o2's only go as high as 570mv or so. Some guys say to ignore the o2's and go by the af ratio. Might be time to dyno this mule!
Thanx for any hlp guys.
