blackdeathtrap
smoking six barrel
- Apr 1, 2010
i have a set of 275 50 15s
my car is lowerd with ebach springs .8 in the back if im not mistaken.
i have a set of knock of center lines made my american racing im not a big fan but il use em if i have to rear is a 15 by 8.5 front is a 14x6 sound im not a huge fan of the look they sit about an inch futter out then the stock gn wheels.
my question is should i run the gn wheels with a spacer or an aluminum drum with the 275 50 15s to keep that stock sleeper ish look.
or will i benifit much more on the wide wheels i will deff have to remove the fender lips in the back if i run the after market wheels and probly roll the fender what is you guys 2 cents other then aperance will i gain alot by using the wider rim .
other option is run them on the stock wheels for now so i can get some seat time with them and next month when i get my back pay from my promotion and purchase these sieng the only 139.95 a rim
http://tires.canadiantire.ca/view/product/CT-Catalog/1417290?qty=4&vehSelUsed=true
or something of the sort maybe go with the craiger soft 8 or d window and just rock the gn center caps im very comfused on what way to go with this
