I am doing the spring cleaning on my car for the first time and I get to the spark plugs and find that the previous owner installed Bosch HR9BP plugs gaped at .50 . So here is my question would this have caused my lean condition with with scan master readings mainly BL 145? All stock car.Here are the scanmaster readings also. I can not run the car with the new plugs AC cr43ts @ .35 because I have the pan down for a rear oil seal change and have not got the gasket yet.
eng.@ idle
234 to 664 00
af 05
lb 39
bat 13.8
int 131
bl 145
mph 00
clt 178
ats 84
r 750
tps .44
iac 25
cc 22-37and counting up
nal 00
eng.@ idle
234 to 664 00
af 05
lb 39
bat 13.8
int 131
bl 145
mph 00
clt 178
ats 84
r 750
tps .44
iac 25
nal 00
