sparkplugs / wires ?
turbobooster
im doing a full tune-up on my car n im not to sure of what is the best spark plug n wires for my car ? its in stoc k conidtion wit 3 in DP w/dump and a k&N air filter its been rebuilt remanufactured wit only 1500- 2000 miles ran or maybe a bit more whats a good spark plug ( inluding gap size for my car) to run on. what is the stock gapping size? and should stick the 8.5mm MSD wires? or what else is a good wire for the engine? thanx
plugs...wires...
Regular ac delco plugs go 1-2 steps colder i think they are 43's..... .35 gap do not use anything else... nothing works better believe me...
magnecore wires... expensive but worth every penny.. they hold up to the heat well...
plugs
i heard to use ac r43cts as the c designation has a larger electrodes that wont burm or melt off as easy.and if you know the hot airs you can burn a set off plug electrodes clean up thru the porclein.
andy
