So...this is what i have found after the initial mock-up:
Pros:
--heavy grade thick stainless with stainless flanges
--beautiful tig welds
--they fit the heads and match the ports beautifully
--very nice looking, and seem well designed
Issues:
Now...be mindful that the engine i mocked them up on has no headgaskets, no intake gasket, no o-rings in the turbo inlet adapter, and the wrong intake bolts that the turbo bracket mounts to....ALL these things will most likely change the alignment of some things...(i was in a hurry)
--The stock o2 sensor bung appears to be aimed directly at where the a/c compressor would be....issue? my take: if you are running a wb o2, or have deleted the a/c...no issue. If you arent, a new or relocated o2 sensor bung would be needed. I cant't confirn that this is indeed an issue without further mock-up or actually putting it in my car.
--The up pipe is about 1/4" too short for the bolts to line up at the turbo....the fix: a 1/4" steel spacer with two gaskets.
--The crossover pipe is where the main issues are....
1) The crossover is too long....its off about an inch...the fix: cut an inch out of the crossover at the slip-fit joint under the oil pan.
2) Where the crossover meets the pass side header, it appears they mistakenly cut the v band flange flush in the header so the two flanges are somehow supposed to mate (and seal) flat against each other?? with no gasket? However, the driver side connection is great. It has the correct flange and it fits nice and snug. the fix: to be determined....
--Up pipe to pass header flange is close to the valve coner maling it impossible to remove the valve cover with the up pipe installed......However, I see no major issue with this as with any other setup, the down pipe and up pipe have to be removed to gain access to the pass side valve cover anyway.
Overall:
Nice design. I like how the up pipe portion is angled differently so as to reduce the bends going into the turbo. Nice looking pieces. with some tweaks to certain areas...I think these would be a great option for our cars. Definitely not a direct bolt-in from the factory....as i expected. the parts in the kit could use some attention as well....I personally wouldnt't bother with the provided gaskets, v bands, and bolts....I would get some higher quality pieces. I feel it odd that they would include header to head gaskets, and an up pipe to turbo gasket, but no gasket for the up pipe to header connection....and no sort of clamp for the 2 piece crossover connection....a simple band style exhaust clamp would work perfect.
I am planning on contacting Speed Daddy this week to see if they are willing to address some of these issues. hopefully they will....and if not, they will get these back, and miss out on the potential of many, many sales of these.....time will tell.
