speed daddy turbo headers
dmarx
OK, I am sure I posted this before, but sure can't find the answer. Hey, it's called CRS syndrome. Just did my last swap meet after 27 years. Body can't take it any more!!!!! The currently listed speed daddy headers for the '84 turbo, how much modification is required for the '79 draw thru?
Dan
'28 Turbo Essex
If you or anyone purchased those headers and wanted them to work on the pre-EFI engines, all that needs done is: throw away every gasket that is included, take a chance on the fake pretend to be V band clamps or cut those off and weld real ones in their place. Then only the short pipe with the turbo flange on it would need cut up and made to fit the inlet on the drawthrough turbocharger.
...and you will need a flanged pipe with 3 bolt hole retainer for the drawthrough turbo inlet as they are not flat like the rest.
