Favian Cuevas
- Jun 26, 2015
Well im thinking of converting to speed density my question is what items do i have to buy?
I already have
3bar map
Powerlogger
I already have
3bar map
Powerlogger
SignUp Now!Ok cool i might just go with an sd chip an as far as the widebrand what is a goos brand to work well with out setupsWideband for sure. And either sd1/sd2 chip or the translator pro and extreme chip for the pro.
Sent from my HTC One using Tapatalk
Hey bison i have a 89 ta map oem one sould iBuy a good MAP sensor.
Any system!When converting to speed density the manifold air pressure (MAP) sensor plays a critical role in the engine tune. There have been recent posts recommending to step up to the AEM 3.5 Bar sensor for improved reliability and accuracy. This goes for Turbo Tweak SD2 or FAST XFI systems.
Chuck
I've used over 200 of these P51 type sensors and never had a failureSo other than the wiring, which isn't too hard to deal with, it's a quality upgrade over the GM stuff. Good to know.
Pm for price. I usually install in manifold below the coil.Brian what's the price of a P51 sensor and typically where are you mounting them? In the manifold?
Thks - aaron
