Speed Pro Plasma Molys
rodman99999
OK- I'm used to installing the bevels toward the top on the 1st and 2nd rings(everything else I've built). The instructions(with the Plasma Molys) say to install the marks toward the top(both 1st and 2nd have a smaller dot than I'm used to seeing), or both bevels toward the top if unmarked. The dot on the 2nd ring will put the bevel toward the bottom. Follow the dots anyway? :confused: Any input from someone experienced with these rings will be appreciated!!
