Hi all,
I'm having a problem with my SpeedPro ECU. I wired up the fuel pump wire to the ground side of my Fuel Pump Relay, but it doesn't appear to me making a connection to ground for me. I confirmed that this wire, when grounded, will enable the pump. But the SpeedPro doesn't seem to do the trick...
Can anyone tell me what to do or check? I haven't found anything in the C-Com that enables/disables the fuel pump, other than the prime time (which I'm not exactly the function of).
I tried to perform a continuity test to ground, and I don't get a connection to ground when I power up the ECU. I don't get one through either the Fuel Pump or Fan wires... Should I?
Any advice? Is it possible that my drivers are bad? How would I test for this? The ECU seems to work otherwise, and the sensors seem to be working as well....
Help!?
Bryan
Help!?
Bryan
