SPI # Question on UA6
VtheGNMan
UA-6 is listed as a : "Theft-deterrent system with Starter Interrupt" in the SPI breakdown options book for an 87 GN.
What is this and how did/does it work?
It lists that AU3 was required too, which is electric door locks. I am assuming this "armed" the system?
If you feel like this should not be posted publically on a forum just PM me.
From what i found out and tried it and it works is . . .
The factory alarm is armed when you lock the door with the drivers side door lock button.
Try doing that with the window down and close the door.
Then reach in and pull up the door unlock button by the window.
When you open your door the horn should start honking.
I believe I put the key in the door and turned it clockwise to disengage the alarm.
Not sure if putting key in the inanition works.
D
D
That's how mine used to work too. I forgot if the parking lights flashed tho. Mine no longer works tho.
