I have noticed that by turning the boost down on my car, I effectively slow the spool to a great degree. I have a ta49 turbo with an adjustable HD actuator obviously. It will spool very fast when the boost levels are over 20, but will degrade big time if I try to bring it down to 17 or so. The rod on the actuator will have no tension at this point so maybe this actuator is only meant for boost levels of ~20 psi and over. So with that said, is it safe to assume that running lower boost levels with this hardware is no longer possible?
