A little back to the top...
I just installed (well, ALMOST installed, stupid velcro!) my SMC kit and I am getting the same problem. When I turn the car on, the green "ARMED" light is glowing. When I push the test button at idle, the car begins to bog. I had my girlfriend push it while I read the outlet alky pressure gauge. 40 psi with pump at half-speed, 60-psi when it's cranked. So I know it's spraying all fine and good. It's just that darn light isn't coming on.
Anybody have suggestions? I thought it may be a bad ground on the inside of the car, but when I disconnected that the "ARMED" light didn't come on, so I know the original ground was good. I wanna get this light to work so I know where my turnon point is. I also would hate to run the tank dry because I didn't get the 'low alky' warning light.
THANKS A LOT!!! I'm pumped to try out the system. I will bother Steve (again) as well!
