85begalttype
just a v6
- Oct 22, 2008
Car ran fine before the 85 maf went bad. Installed a 86-87 ecm, maf, tt chip, and an adjustable fuel pressure regulator all at once. Adjusted fuel pressure to 43psi line off.
When im idling at a stop light, then give it gas to take off, it sorta bogs down and sputters. But if i slowly accelerate, it takes off fine. Happens only at idling engine speed. Car runs good and accelerates fast otherwise.
I cant afford a scanmaster at the moment, so im trying the best i can do with a digimeter to check things, tps at idle is around .43, have no clue what the iac is set at.
