Square alky bottle relocation with dual fans help.
wiked87gn
Banned
anybody know where to relocate the square bottle from SMC with dual ramcharger fans, pics would be nice also i cannot move my vapor canister hence airfilter is already down there with a cold airkit.
thanks
I relocated mine by buying a small piece of aluminum from Home Depot. I cut it to length with a hack saw and drilled holes in it. I mounted it using the 2 intercooler bracket bolts (passenger side). It is flexible enough to bend to fit, but doesnt move around when mounted. If you want pics I can take some tonight and email you? It works/looks ok but I eventually will use the coolant overflow bottle for alky.
HTH
