I've been considering buying & building a 3.8 stage 1 off center with a 3.625 BSM crank. The plan would involve using all stock power acc, intake, oiling system, headers, etc.
Some of my questions are....
What kind of reliable hp can be produced with this block using a BSM crank & the 2 bolt BSM caps that came with the block? (Is it stronger than a gridled 109?)
Are there any oiling mods that should be preformed to the block?
Were these blocks subject to the misaligned 3# lifter bore?
Any problem areas noted with these blocks, ie. splitting, cracking, etc?
