Stage 2 Engine Parts Needed for Hotrod
Duntov
I am planning on putting a Stage 2 "look alike" motor in my street rod project. Top end is a Kinsler setup. I am not building a race motor but mainly for looks. So I need the necessary components to get what I need on a tight budget. Parts do not have to be perfect but serviceable.
My plan is to use a stock OEM 231 block. Right now I am looking for the cast valve covers and a set of heads go go along with the Kinsler setup.
LMK,
John
Keep in mind that you might have valve clearance issues with the cylinder bores when using big valved heads on a 3.8L block.. I believe this might be a problem anyway.
